AutoCAD Forum
DWG Trueview 2013 shows block frames (DWG from AutoCAD 2006)
2 REPLIES 2
Tothgra
2249 Views, 2 Replies
Hy All!
I use AutoCAD 2006 to create my drawings. I save it in DWG format 2000. My coworkers can open my drawings only in DWG Trueview 2013 or 2012. If they do so, they see all the frames from the blocks. In AutoCAD 2006 they don't show up.
This is the drawing in True view:
This is the same DWG in AutoCAD2006:AutoCAD 2006 - [NCADDATAAL-SSH-PMK-CADAutoCADSzombathelyH4SSH_G17_1_0_v01_2014-06-16_12-47-37.jpg
 My question is, how can i turn these frames off???
Greetings from Hungary,
Tothgra
2 REPLIES 2
pendean
in reply to: Tothgra
There is no reason why they cannot open your files without the viewer: are you or your file really from plain AutoCAD 2006 or a vertical like ARCH or CIVIL or others?
Those 'boxes' look like ProxyObject bounding boxes.
Post the actual DWG file if you are not sure.
Tothgra
in reply to: pendean
This are XCPILFRAMES. And i set them, in AutoCAD OFF. Then when somebody opens the file in DWG TrueView the XCLIPFRAMES shows up again. It is an anoying problem, but i found the solution. I must save my drawings in DWG 2004 and the XCLIPFAMES are gone.
”Boost
