AutoCAD 2004/2005/2006
Active Contributor
mcnamake
Message 1 of 7 (351 Views)
drawing file is not valid
351 Views, 6 Replies
09-19-2007 03:19 PM
hi.. i am trying to open a drawing, but it says that "drawing file is not valid". However, I can see the drawing in the preview window. Any suggestions.
thank you,
Ken
*Leo the Builder
Message 2 of 7 (351 Views)
Re: drawing file is not valid
09-19-2007 03:44 PM in reply to: mcnamake
Try recover.
If you have the .bak file try and rename that to a .dwg file and open.
Leo
*Dean Saadallah
Message 3 of 7 (351 Views)
09-19-2007 07:32 PM in reply to: mcnamake
FYI, preview is just an image/snapshot buried in the dwg, it is NOT
and NEVER is/was an indication of what's in the file or the state of
the file.
It means nothing at all the you can see the preview.
If the other suggestion fails, try to INSERT the file into one of
yours. You can also try a partial Open.
You can also try the free autodesk converter to try and change it's
version number and see if that helps.
Dean Saadallah
http://LTisACAD.blogspot.com
Add-on products for LT
http://www.pendean.com/lt
*Warren Trost
Message 4 of 7 (351 Views)
09-20-2007 06:02 AM in reply to: mcnamake
Is this from a newer version of AutoCAD saving in the 2007/2008 format?
wrote in message news:5726574@discussion.autodesk.com...
suggestions.
thank you,
Ken
*R.K. McSwain
Message 5 of 7 (351 Views)
09-20-2007 06:21 AM in reply to: mcnamake
Warren Trost said the following on 9/20/2007 8:02 AM:
I thought of that also, but he would not be able to see the preview if
the DWG file was a newer version.
R.K. McSwain
http://rkmcswain.blogspot.com
*Warren Trost
Message 6 of 7 (351 Views)
09-20-2007 01:44 PM in reply to: mcnamake
I had thought originally he was viewing in explorer. Need to read more
carefully. <:->(
"R.K. McSwain" wrote in message
news:5726997@discussion.autodesk.com...
R.K. McSwain
New Member
bmccoy12345
Message 7 of 7 (257 Views)
04-25-2011 09:11 AM in reply to: mcnamake
Is there a way to get the information that is in the snapshot view from explorer back?
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
