Something happend...
If I draw a 3D-box size 100x100x100 and then view it in perspektive. Then I want to copy the box from the bottom endpoint to the upper endpoint - the copy still remanes on ground level. I have to use "copy" @0,0,100 to get it up.
I must have changed some setting by misstake. Can anyone help me with this?
/mazken
The OSNAPZ variable is availabile in AutoCAD2006 and newer. OSNAPZ=0 is the legacy behavior where AutoCAD will use the Z value of the snap point. OSNAPZ=1 will cause AutoCAD to ignore the Z value of the snap point and instead use the current ELEVATION.
If using 2006 or newer Tools > Options > Drafting > Replace Z value with current elevation
-or-
OSNAPZ = 0 at the command line
I see.
The problem is that I have AutoCad 2005 , included in Mechanical Desktop, but I only use AutoCad.
So the OSNAPZ is not a existing command. I don't even have a drop down menu named Tools...
There must be a way to do it. Probably something easy since I think I have changed it by misstake and I am seldom doing changes in the settings.
Finally I found the answer.
The drop-down-menu: Assist
Choose: Drafting Settings
Then click on: Ignore Z Coordinate On/Off
How I accidently did that I don't know. Probably there is a button for that - but I don't know whitch 😉
/design
