AutoCAD 2004/2005/2006
Valued Contributor
vandenoosterkamp
Message 1 of 7 (1,624 Views)
Disable F1, F7 and F9 keys?
1624 Views, 6 Replies
04-03-2007 07:02 AM
Is there a way to disable those keys?
I hit them sometimes by accident and almost never use help, grid or snap...
Distinguished Contributor
C O Jones
Message 2 of 7 (1,624 Views)
Re: Disable F1, F7 and F9 keys?
04-03-2007 08:32 AM in reply to: vandenoosterkamp
The irony is the F1 key will bring up help, which will help you to modify the Function Keys.
This has been talked about a lot in the past in here, also search here for F1 or F1 key.
good luck
*Joe Bouza
Message 3 of 7 (1,624 Views)
04-03-2007 09:13 AM in reply to: vandenoosterkamp
....."I hit them sometimes by accident"...?
Maybe some typing lessons are in order ?
My function keys seem far way comparitivley speaking of course.
Joe
wrote in message news:5539894@discussion.autodesk.com...
the Function Keys.
F1 or F1 key.
good luck
*Dean Saadallah
Message 4 of 7 (1,624 Views)
04-03-2007 02:21 PM in reply to: vandenoosterkamp
Sounds like you need to disable all F-keys and reassign
Ortho to something easier to aim at... . Like F12 perhaps.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
Valued Contributor
vandenoosterkamp
Message 5 of 7 (1,624 Views)
04-04-2007 02:40 AM in reply to: vandenoosterkamp
LOL, after 10 years of autocad my left hand is far more used to type then my right hand, so typing lessons will be useless I guess and probably injure my right hand ;-)
Thanks for the F1 search tip, I found a great explanation here:
http://discussion.autodesk.com/thread.jspa?messageID=4916722
Member
JHeilman258
Message 6 of 7 (1,535 Views)
08-11-2011 08:26 AM in reply to: vandenoosterkamp
So I understand that everyone here is an arrogant (ignorant) user. Excpet of course the individual who asked the question. Looks like I accidentally spelled "except" wrong. Well, guess I should take typing lessons. Here's a tip, if you don't know the answer then don't respond.
You can do this by going into the CUI (customize user interface):
  1. Right-click a toolbar and click Customize or enter CUI on the command line.
  2. In the upper-left section of the CUI dialog box, expand Keyboard Shortcuts > Shortcut Keys.
  3. In the Command List, right-click the Cancel command. Click New Command. A new command will be added to the bottom of the list.
  4. Right-click the new command. Click rename.
  5. I renamed mine to Disable - F7, Disable - F9, I personally don't mind the F1 so much
  6. Drag the new command into the Shortcut Keys section.
  7. Select the new command from the Shortcut Keys list. Under Properties, in the lower right-hand corner, click the Keys line and click the Small button. (thats the button with the "...")
  8. Hit the key you want to use for this "do nothing command" i.e. F7 or F9 or F1
  9. click assign
  10. click apply
  11. try it out.
check out the attachment to clarify. it isn;t exactly what you want to do but it will give you thge right idea.
Everybody else in this forum can go to hell. oh...look instead of isn't i ACCIDENTALLY typed isn;t.
Active Contributor
betazero
Message 7 of 7 (709 Views)
09-09-2013 08:33 AM in reply to: JHeilman258
I know this is from a long time ago but I would just add one thing because I found it very helpfull. Delete the macro line in the command if you want those keys to do absolutely nothing. Otherwise it will cancel out whatever command you may be in.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
