AutoCAD 2004/2005/2006
Valued Contributor
scatman99
Message 1 of 4 (3,457 Views)
DIMENSION FORMULA
3457 Views, 3 Replies
10-10-2005 06:56 AM
Is it possible to use a formula in the alternate units area of a dimension style that would divide the length of the dimenions by say 300 and then add 2 to that answer.
For example:
If the dimension length was 3000mm, divide this number by 300 to get 10 and ten add 2 to this number to get 12.
So the number in the alternate units area would read 12.
Ant help would be appreciated.
Regards Paul
Product Support
Silvia.Menon
Message 2 of 4 (3,448 Views)
Re: DIMENSION FORMULA
09-20-2010 09:35 AM in reply to: scatman99
better late than never ;-)
You can do this in AutoCAD 2011 but it requires a bit of tweaking.
1. create a dimensional contraint on the object you want to dimension
2. draw your dimension
3. DDEDIT > pick the dimension text, delete the curent value > right click and select "Insert Field"
4. In the Field dialo box, under Field names, select "Formula"
5. right-click in the Formula field and select "Insert Field" again
6. in the Field dialog box, under Field names, select "Object"
7. pick the dimensional contraint you created in step1
8. Under "Property", select "Expression"
9. click OK to close this field dialog box
10.back in the first dialog box you now have the value of the dimensional contraint in the formula field and can add your desired formula to it (example: +2)
11. click OK
12. Voilà: You dimension now shows the calculation as desired.
Hope it all makes sense - I have attached a sample file to make it more clear. The "formula" dimension is the red one.
Best regards
Silvia
Silvia Menon
Support Specialist
Product Support
http://www.autodesk.com/autocad-support
khoshravan
Message 3 of 4 (2,899 Views)
08-15-2011 09:03 PM in reply to: Silvia.Menon
suppose we have 100 dimension lines and we want to aply this formula to all of them.
If we apply to only one, will the other 99 one change automatically, or we need to apply it one-by-ome to all of them?
Is this method applicable in ACAD 2010?
TIA
Khoshravan
civil Engineer
New Member
murali
Message 4 of 4 (1,372 Views)
06-20-2013 12:20 AM in reply to: scatman99
You can use update command
