AutoCAD 2004/2005/2006
New Member
0 Kudos
Post 1 of 5
CutePDF problem
275 Views, 4 Replies
04-07-2005 12:23 PM
Does anybody know how i can solve the problem of not being able to print in metric (mm) scale when i try to convert a dwg. into a pdf.? WIth other plotters this is possible, but whenever i change the plotter to "CUTE PDF." (pdf. coverter), the plot to scale box immediately changes into inches and it cannot be changed to 'mm' no matter what size paper i use.
*Pro
80 Kudos
Post 2 of 5
Re: CutePDF problem
04-07-2005 12:28 PM in reply to: Andrew Tsang
Get PushButton PDF by BlueBeam
Distinguished Contributor
1 Kudo
Post 3 of 5
Re: CutePDF problem
04-07-2005 12:40 PM in reply to: Andrew Tsang
Interesting one...no problem for us - you have the latest mm toggle patch installed from the autocad support?
May also be because we do have adobe writer as well, and not just cuteprinter alone - maybe adobe is the reason we have no problem even if we do select the cutepdf printer.
*Tracy W. Lincoln
Post 4 of 5
Re: CutePDF problem
04-07-2005 01:52 PM in reply to: Andrew Tsang
http://tinyurl.com/4uhp3 -- Tracy W. Lincoln - TLConsulting http://TLConsulting.blogspot.com/ Consulting, Design & Training Specialist Autodesk Discussion Group Facilitator "Andrew Tsang" wrote in message news:9347631.1112901835358.JavaMail.jive@jiveforum1.autodesk.com... > Hi, > > Does anybody know how i can solve the problem of not being able to print in metric (mm) scale when i try to convert a dwg. into a pdf.? WIth other plotters this is possible, but whenever i change the plotter to "CUTE PDF." (pdf. coverter), the plot to scale box immediately changes into inches and it cannot be changed to 'mm' no matter what size paper i use.
*The Real JD
Post 5 of 5
Re: CutePDF problem
04-07-2005 01:53 PM in reply to: Andrew Tsang
I'ved used the Cutepdf alone.. it works fine.. i would check that you have the toggle plotting patch.. and create a PC3 for the printer driver. It works fine for me. "Andrew Tsang" wrote in message news:9347631.1112901835358.JavaMail.jive@jiveforum1.autodesk.com... > Hi, > > Does anybody know how i can solve the problem of not being able to print in metric (mm) scale when i try to convert a dwg. into a pdf.? WIth other plotters this is possible, but whenever i change the plotter to "CUTE PDF." (pdf. coverter), the plot to scale box immediately changes into inches and it cannot be changed to 'mm' no matter what size paper i use.
