AutoCAD 2004/2005/2006
0 Kudos
Post 1 of 1
Copying XREFs
93 Views, 0 Replies
05-06-2008 06:18 AM
One of our Architects submits the following issue. Any insight is greatly appreciated.
We have a base plan for a hotel floor into which we have unit plans xrefed/overlay/relative path. The xref is then copied/flipped/moved to fill out the floor plan. The problem is when the contractor opens the base plan they only see the unit xrefed in its original location and do not see the copies.
They tell me that if our file was attached then copied/flipped/moved it would work? Have you encountered this problem or do you have any ideas what could be causing it?
