AutoCAD 2004/2005/2006
New Member
0 Kudos
Post 1 of 9
Controling Draworder
114 Views, 8 Replies
04-09-2004 07:20 AM
Just a suggestion, but would it be possible to establish a layer draworder control similar to what you see in photo manipulation software such as Corel or Adobe where the layer stacking is set (and held) by its position in the list. We are continually having to reorder our drawings. At the least is it possible to have the draworder stay constant instead of always resetting the last edited item to the front.
Distinguished Contributor
1 Kudo
Post 2 of 9
Re: Controling Draworder
04-10-2004 10:19 AM in reply to: msykes
Amen to that suggestion. That's the way I thought draworder should work also. Has anyone written a lisp routine to do this ?
Thanks.
Tim Rathbun
Active Contributor
0 Kudos
Post 3 of 9
04-16-2004 09:12 AM in reply to: msykes
Let's be clear on one thing... I don't want to have to use the normal layer dialog sorting to order the layers for draworder purposes... but if they add a "Draworder Manager" that let's you set draworder by color, layer, entity, etc... and order them within that function, THAT would be incredible.
*Terry W. Dotson
Post 4 of 9
04-18-2004 03:50 PM in reply to: msykes
Trey Monsour wrote: > Let's be clear on one thing... I don't want to have to use the normal > layer dialog sorting to order the layers for draworder purposes... > but if they add a "Draworder Manager" that let's you set draworder by > color, layer, entity, etc... and order them within that function, > THAT would be incredible. You know, I'm *sure* that something like that could have been included in 2005, if only ... Terry
0 Kudos
Post 5 of 9
04-19-2004 04:48 AM in reply to: msykes
Yeah, then draworder will become just a normal property like width or color. Good thinking !
Most of the people wil then draw with draworder "bylayer"
the Layer dialogue would have a new column "draworder" (on witch you can sort if you need to edit this) and the Plot Styles then would also be albe to manage this, because perhaps it's mor eays to work with Layer0 on tob, but on the plot, Layer2 should be plotted "on top"
Just dreaming aloud....
Active Contributor
0 Kudos
Post 6 of 9
04-19-2004 06:40 AM in reply to: msykes
I'm sure there are a lot of ways you can do it, and everyone has their own way of drawing (which would play a large role in how they would want draworder to work. That's why I suggested a draworder manager, where you could just do it however you wanted... not just bylayer, bycolor, by entity, by creation order, etc... When the AUGI comes back up, maybe we all should put in requests for something like this on the wish list.
*Lawrence Stamp
Post 7 of 9
04-20-2004 07:10 AM in reply to: msykes
Great Idea Terry! Hint :-) Larry "Terry W. Dotson" wrote in message news:40830621$1_1@newsprd01... > Trey Monsour wrote: > > > Let's be clear on one thing... I don't want to have to use the normal > > layer dialog sorting to order the layers for draworder purposes... > > but if they add a "Draworder Manager" that let's you set draworder by > > color, layer, entity, etc... and order them within that function, > > THAT would be incredible. > > You know, I'm *sure* that something like that could have been included > in 2005, if only ... > > Terry
0 Kudos
Post 8 of 9
04-20-2004 03:07 PM in reply to: msykes
In 1999 I wrote a little lisproutine called Layorder.lsp that asks you to select an object and brings that whole layer to the front or sends it to the back. Actually it's not for free: 50 euro's or 60 dollars, but as I am in a very good mood I give you the source code, on the sole condition that you don't change the copyright notice:
;LAYORDER
;Sends all objects on a selected layer to the front or back.
(prompt "\nLayOrder (c) 1999-2003 IDEOMA intelligent systems b.v.")
(prompt "\nSends all objects on the selected layer to the front or back.")
(defun c:layorder ()
(setvar "cmdecho" 0)
(initget "Front Back")
(setq
frobac (getkword "\nMove layer to Back/: ")
frobac (if frobac frobac "Front")
layorder_max (if layorder_max layorder_max 500)
xx (prompt "\nPress Enter for the current layer")
en (car(entsel))
la (if en (cdr(assoc 8 (entget en)))(getvar "clayer"))
ss (ssget "x" (list (cons 8 la)))
(if (> (sslength ss) layorder_max)
(prompt (strcat "\n" (itoa (sslength ss)) " objects on this layer. (Max " (itoa layorder_max) ")"))
(progn
(command "draworder" ss "" frobac)
(prompt (strcat "\n" (itoa (sslength ss)) " objects on layer " la " moved to " frobac "."))
(princ)
(prompt "\nCommand LAYORDER added.")(princ)
0 Kudos
Post 9 of 9
04-20-2004 03:11 PM in reply to: msykes
Sorry, I just discoverd that I can attach files, so here it comes.
