AutoCAD 2004/2005/2006
New Member
ghunt
Message 1 of 5 (326 Views)
Can't insert blocks using object snaps
326 Views, 4 Replies
02-27-2006 10:06 AM
If I try to insert a block using an osnap, it will not snap to that point. However, if I insert it without using an osnap, it comes in fine. Then, I can move the block using my osnaps. I've checked my variables & come up empty. Anyone have any ideas?
*Dean Saadallah
Message 2 of 5 (326 Views)
Re: Can't insert blocks using object snaps
02-27-2006 10:51 AM in reply to: ghunt
How are you inserting this block? There are many ways and
variations: use a command name and process to narrow it
down.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
*Leothebuilder
Message 3 of 5 (326 Views)
02-27-2006 11:36 AM in reply to: ghunt
Also, check the base point in the block.....make sure it ain't somewhere out
in WhoopWhoop.
Leo
"Dean Saadallah" wrote in message
news:5097014@discussion.autodesk.com...
down.
Dean Saadallah
*Dean Saadallah
Message 4 of 5 (326 Views)
02-27-2006 01:49 PM in reply to: ghunt
WhoopWhoop? Is that near Timbuktu? :smileyhappy:
gc_broach
Message 5 of 5 (308 Views)
08-04-2010 11:46 AM in reply to: ghunt
Did you ever find the answer to this problem? We are having the same thing in 2011. it works fine in 2010 and earlier
I have posted the same question and had no replies..
