AutoCAD 2004/2005/2006
*Luedke, Matt
Message 1 of 3 (48 Views)
Bad File Help
48 Views, 2 Replies
07-09-2003 05:21 AM
My PC decided to restart on its own, I was in AutoCAD at the time and when I
try to reopen the file it needs recovery but won't recover. I tried to add
it as a block in a new file and it says it an invalid file, same goes for
xref. Anyone know if I can try anything else.
Matt
*Page, Jon
Message 2 of 3 (48 Views)
Re: Bad File Help
07-09-2003 06:17 AM in reply to: *Luedke, Matt
There should be a backup file with the .bak extension or possibly an
autosave file that you could use. It is very strange that the xref is bad.
Were you in the middle of a refedit of the xref? Otherwise that file was
not open for writing at the time your computer shutdown and should not be
affected.
Have you had problems with any other files since the restart occurred?
What operating system are you using?
Jon
autodesk
"Matt Luedke" wrote in message
news:028A25C0FE9AF1AD69DE7ACC72A88834@in.WebX.maYIadrTaRb...
I
> Matt
*Luedke, Matt
Message 3 of 3 (48 Views)
Re:
07-09-2003 06:19 AM in reply to: *Luedke, Matt
The backup is several hours old, and the autosave is missing. I tried to add
the file as an xref to recover it but that didn't work also. So I'm stuck
unless some one another option to try.
"Jon Page" wrote in message
news:18C3C84F4A4F058876912F8B9BCCFC0E@in.WebX.maYIadrTaRb...
bad.
> affected.
> Jon
> autodesk
when
> I
add
for
> > Matt
Post to the Community
New Post
Need installation help?
