AutoCAD Forum
AutoCad 2002
11 REPLIES 11
Message 1 of 12
jhgt3
353 Views, 11 Replies
AutoCad 2002
I just started with this Engineering firm (civil) and they are running AutoCAD 2002, my problem is that Express tools is not working at all, the icons are there, the ACET files are present.  I get this message ; error: no function definition: ACET-AUTOLOAD2, does anyone know what may be wrong with my application?  Every express command is followed by unknown command.  Can anyone out there help?!!
11 REPLIES 11
Message 2 of 12
Patchy
in reply to: jhgt3
maybe DEMANDLOAD is not setting right, try 3
Message 3 of 12
jhgt3
in reply to: Patchy
demandload is currently set to 3
I was wondering is the express folder suppose to show up in the Working Support File Search Path as it does in the Support File Search Path?
Message 4 of 12
Patchy
in reply to: jhgt3
EXPRESS FOLDER It should be in the search path in OPTIONS
Message 5 of 12
jhgt3
in reply to: Patchy
ok so, under Options, Files, so you are saying in the Search Path for ObjectARX Applications?
Message 6 of 12
jhgt3
in reply to: Patchy
I guess what I'm asking is, which search path?
Message 7 of 12
Patchy
in reply to: jhgt3
Have you tried the command EXPRESSMENU or MENULOAD and see if E.T. is in there? if not:
Use Windows Search, find where the EXPRESS folder is in your PC.
Go to OPTIONS and add the new path to that folder.
EXIT Autocad and restart is required to make it work.
Message 8 of 12
jhgt3
in reply to: Patchy
Patchy Mine looks like that except it is C:\Program Files\AutoCAD 2002\Express
Message 9 of 12
jhgt3
in reply to: jhgt3
OMG I just removed Express tools from menuload, how do I get it back?  HELP!!
Message 10 of 12
Patchy
in reply to: jhgt3
Type in EXPRESSMENU it will come back.
Message 11 of 12
jhgt3
in reply to: Patchy
I had to reload it from installation disk.  so now that I reloaded it I still cannot get Express tools to work, I have file in search path, loaded express from menuload everytime I start up it says, error; bad function, I even loaded the Expbuilder.dll (2) files, at this point I dont know what elso to do.  I show a happy face with sunglasses icons, I'm at wits end!!  Any other ideas?
Message 12 of 12
Patchy
in reply to: jhgt3
Find acettest.fas, acetmain.hlp, acetmain.cnt, and acetfaq.hlp files and move them to Express Folder.
On the command line, type appload and press ENTER.
Under Startup Suite, select Contents and choose Add.
Select the acettest.fas file in the Express Folder.
Restart AutoCAD.
Type in: expressmenu on the command line
Hope this will work
”Boost
