AutoCAD 2004/2005/2006
Valued Contributor
mickowitz
Message 1 of 8 (154 Views)
Associative dimension problems!
154 Views, 7 Replies
08-12-2005 04:07 PM
I have associative dimensions created in paperspace. When I edit the underlying XREF and go back to these dimensions, they have gone all out of whack. DIMLFAC is set to 1, DIMASSOC is set to 2.
At the same time, when I try to add new dimensions to this same paperspace, they do not show the correct dimension, BUT, if I manually reassociate any of the existing and/or screwed up associative dimensions, they do continue to show the correct dimensions. All of these dimensions are the same dimstyle. I have to delete all of these dimensions and start all over again.
I am so confused! I've looked through the topics and tried to fix this without success. Help!
*Bill DeShawn
Message 2 of 8 (154 Views)
Re: Associative dimension problems!
08-13-2005 08:29 AM in reply to: mickowitz
As far as I know, dimensions created in paper space don't retain
associativity to objects in model space. I believe your dimensions need to
be created in the same space as the objects you are dimensioning. If I am
wrong, it would be wonderful, however, so far, I have not been living in a
perfect world.
Bill DeShawn
bdeshawn@nospamsterling.net
http://my.sterling.net~bdeshawn
wrote in message news:4927913@discussion.autodesk.com...
*R. Robert Bell
Message 3 of 8 (154 Views)
08-13-2005 09:07 AM in reply to: mickowitz
DimAssoc=2
R. Robert Bell
"Bill DeShawn" wrote in message
news:4928092@discussion.autodesk.com...
perfect world.
Bill DeShawn
*Bill DeShawn
Message 4 of 8 (154 Views)
08-13-2005 09:40 AM in reply to: mickowitz
Robert:
Did you see that Mickowitz sets DIMASSOC to 2 but he still has the problem?
Bill DeShawn
"R. Robert Bell" wrote in message
news:4928110@discussion.autodesk.com...
DimAssoc=2
R. Robert Bell
perfect world.
Bill DeShawn
*Dave Byrnes
Message 5 of 8 (154 Views)
08-13-2005 11:02 AM in reply to: mickowitz
If DIMASSOC = 2, paper space dimensions DO retain associativity with model
space items. If you stretch an object in model space, the dimensions
automatically update in the layout.
If the model space objects are xrefs, the dimensions have to be reassociated
on the layout.
Dave Byrnes / Vancouver, BC
Autodesk Discussion Group Facilitator
perfect world.
Bill DeShawn
*Ian A. White
Message 6 of 8 (154 Views)
08-13-2005 02:02 PM in reply to: mickowitz
On Sat, 13 Aug 2005 16:40:39 +0000, Bill DeShawn
wrote:
>Robert:
As of 2002, not all objects worked correctly with DIMASSOC set to 2. It
looks like at least some of this has been carried over to 2006.
Ian A. White, CPEng
WAI Engineering
Sydney 2000
Australia
Ph: +61 418 203 229
Fax: +61 2 9622 0450
Home Page: www.wai.com.au
mailto:ianwhite@wai.com.au
callto://waiwhite on Skype
*Bill DeShawn at Gregg Creghton's Office
Message 7 of 8 (154 Views)
08-15-2005 10:10 AM in reply to: mickowitz
Thank you, David. I think this is the answer that Mickowitz needs.
____________________
Bill DeShawn
Please reply to group only
Thank you
http://my.sterling.net/~bdeshawn
"Dave Byrnes" wrote in message
news:4928109@discussion.autodesk.com...
on the layout.
perfect world.
Bill DeShawn
Member
michel.lapointe
Message 8 of 8 (154 Views)
06-02-2006 04:49 AM in reply to: mickowitz
I've noticed the same thing on my projects and I don't use any XREF. My dimassoc is set to 2 but at times dimensions wont association and I need to use the reassociate command. Once reassociated they stick. It happens enough that I added a reassocatiate button to my dimensioning toolbar.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
