AutoCAD 2004/2005/2006
*Scott Townsend
Message 1 of 4 (811 Views)
Align and Distribute Objects?
811 Views, 3 Replies
06-14-2004 05:27 PM
I'm looking for a way to Align and distribute objects. I remember getting some tools to do this for 2000, but that machine is long since gone.... )-; Any assistance would be appreciated. Thanks, Scott<-
*Dean Saadallah
Message 2 of 4 (811 Views)
Re: Align and Distribute Objects?
06-14-2004 06:25 PM in reply to: *Scott Townsend
ALIGN command? -- Dean Saadallah Add-on products for LT http://www.pendean.com/lt --
*Scott Townsend
Message 3 of 4 (811 Views)
06-14-2004 07:14 PM in reply to: *Scott Townsend
I found that, though I think I need to see the manual page to see if it can do what I want. For instance aligning: I want to align 27 text objects to the left most part of the left most object. -- Or -- I have 14 symbols almost the same size. I want to align them by the center of each object. -_ so -_ Align top/bottom would be ---- Distribute I want the 27 text objects to be evenly top/bottom distributed between the top most object and the bottom most object. I've used OSnap, though thats only one object at a time... Pretty time consuming. This is a freature on Actrix and Visio, is it Burried in AutoCAD somewhere? "Dean Saadallah" wrote in message news:40ce5012_1@newsprd01... > ALIGN command? > > -- > Dean Saadallah > Add-on products for LT > http://www.pendean.com/lt > -- > >
*Tracy W. Lincoln
Message 4 of 4 (811 Views)
06-14-2004 08:52 PM in reply to: *Scott Townsend
Try DIVIDE or MEASURE (and look at the BLOCK option, use a Block, even if temporary) -- Tracy W. Lincoln Autodesk Discussion Group Facilitator http://www.autodesk.com/discussion-announcements "Scott Townsend" wrote in message news:40ce5b6c$1_3@newsprd01... > I found that, though I think I need to see the manual page to see if it can > do what I want. > > For instance aligning: > > I want to align 27 text objects to the left most part of the left most > object. > -- Or -- > I have 14 symbols almost the same size. I want to align them by the center > of each object. > -_ > so -_ Align top/bottom would be ---- > > Distribute > > I want the 27 text objects to be evenly top/bottom distributed between the > top most object and the bottom most object. > > I've used OSnap, though thats only one object at a time... Pretty time > consuming. > This is a freature on Actrix and Visio, is it Burried in AutoCAD somewhere? > > > "Dean Saadallah" wrote in message > news:40ce5012_1@newsprd01... > > ALIGN command? > > > > -- > > Dean Saadallah > > Add-on products for LT > > http://www.pendean.com/lt > > -- > > > > > >
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
