AutoCAD 2004/2005/2006
Distinguished Contributor
mdent
Message 1 of 4 (197 Views)
3D SOLIDS
197 Views, 3 Replies
01-29-2007 12:31 PM
If you draw a rectangle in 2D, and extrude it to some height, is the object considered to be a "3D solid object"?
Once shaded, it obviously appears to be "a solid".
I will be working with a 3D solids modeling program that does 'collision checking" with other 3D solids. If the extruded rectangle is a solid object, it will save me the expense of upgrading to some other AutoCAD product for the time being. At least until we are comfortable running the 3D program. We don't want to be learning two new software's at the same time.
Help is appreciated.
*Jason Rhymes
Message 2 of 4 (197 Views)
Re: 3D SOLIDS
01-29-2007 12:42 PM in reply to: mdent
If you LIST the object it should show you what it is and it should be a
solid.
*Expert Elite*
JDMather
Message 3 of 4 (197 Views)
Re: 3D SOLIDS
Yes, it is a solid.
Use the ACISOUT command to save in a neutral file format (*.sat) for importing into the other software. (Assuming the other software won't read ACAD solids directly.)
Which begs the question, if you don't know how to do solids in AutoCAD then why bother learning now if they can be modeled in the other software?
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
*Sanjay Jamalpur
Message 4 of 4 (197 Views)
Re: 3D SOLIDS
01-30-2007 09:46 PM in reply to: mdent
Yes off course it is a 3D-solid when you extrude the 2d-rectangle using
extrude command you can list out all the solid model properties using list
command.
Sanjay Jamalpur
- Four Dimension Technologies
[www.4d-technologies.com]
- Get GeoTools, Work smarter: www.4d-technologies.com/geotools
- Free Lisp downloads @ TechCenter: www.4d-technologies.com/techcenter
wrote in message news:5467599@discussion.autodesk.com...
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
