AutoCAD 2004/2005/2006
Active Contributor
0 Kudos
Post 1 of 6
3d coordinates of node
199 Views, 5 Replies
02-28-2006 12:44 PM
I know that we can extract coordinates when we have a block in Autocad.
My question is how do we extract those coordinates when we only have nodes or points.
Thank you
Distinguished Contributor
0 Kudos
Post 2 of 6
Re: 3d coordinates of node
02-28-2006 01:18 PM in reply to: louise3d
Not sure if this is what you are after but ID, enter, pick point.
Active Contributor
0 Kudos
Post 3 of 6
02-28-2006 01:29 PM in reply to: louise3d
No This is not what I am looking for.
I want to extract my coordinates into an ASCII file or Excell file just like when we do it with a block when we do extract attribute.
3 Kudos
Post 4 of 6
02-28-2006 01:34 PM in reply to: louise3d
Search this forum for more info on extracting coordinates. I recall some discussion a few months back on this and possibly even a lsp routine that worked.
*Allen Jessup
Post 5 of 6
02-28-2006 01:42 PM in reply to: louise3d
About the best you can do in vanilla autocad is list the points. Then
copy/paste from the text window to a text editor. Then you will have to edit
out the extra data.
Try asking in the customization group or searching the internet. It
shouldn't be too difficult to write a lisp routine to do this.
Allen
The following will replace all points on layer work with a block named pnt.
(defun C:smileytongue:2B ()
(setq ARQ (getvar "ATTREQ"))
(setvar "ATTREQ" 0)
(setq count 0
SST (ssget "X" '((0 . "POINT")(8 . "WORK")))
(while (< count (sslength SST))
(setq ENT (entget (ssname SST count)))
(setq INSP (cdr (assoc 10 ENT)))
(command "-insert" "pnt" insp "" "" "")
(setq count (1+ count))
(setvar "ATTREQ" ARQ)
wrote in message news:5098250@discussion.autodesk.com...
New Member
0 Kudos
Post 6 of 6
03-02-2012 12:45 AM in reply to: *Allen Jessup
What if the model is 3Dmodel and i want to extract the data result from the nodes at the middle of the part thickness?
In 3D model, normally there are 6 layers in meshing. However, in the results, it is very difficult to identify which node is at the middle of the layer.
Anyone can help?
