seems autodesk removed the link to download 2004 sp1a unlocked serve pack? im looking for alink or a way to redownload it.
brian
Solved by jessica.t. Go to Solution.
Hi Brian,
I have just emailed you the AutoCAD 2004 Service Pack 1 zip file directly to you. The file is too large to host in the forums, so I hope that was okay.
However I must warn you that this file is quite old and falls far beyond our scope of support so I hope that it works for you.
If you have any other questions please respond to this post. Thank you!
AutoCAD 2004 SP1a unlocked is still available on Autodesk servers - see the link(s) on:
http://www.cadforum.cz/cadforum_en/download.asp?cat=3&file=2004
Vladimir Michl, www.cadstudio.cz www.cadforum.cz
