Not sure on the reinstall without, as I always have repatched and reupdated
with any reinstall.
DO NOT send technical requests to me via private e-mail
Tracy Lincoln
Assistant Moderator, Autodesk Discussion Groups
Discussion Group Links:
Index: http://discussion.autodesk.com
Rules: http://discussion.autodesk.com/webx?groundrules
Product Support: http://support.autodesk.com/
Knowledge Base: http://support.autodesk.com/ViewAnswerworks.asp
Downloads: http://support.autodesk.com/Downloads.asp
Accurate wrote:
I
have SP2 Installed. Unless when I did a reinstall to correct files
(not an uninstall), it may have deleted or changed some of the files from
the service pack. Does anyone know whether when you do a reinstall,
do you have to also reinstall all of the service packs and plotter upgrades
as well? Thanks
A Technical Solution has been written about this:
More text underlined than expected when using Multiline Text Editor
http://support.autodesk.com/getdoc.asp?id=TS47474
Tracy Lincoln
Accurate wrote:
I
as well? Thanks
"Tracy W. Lincoln" <Accurate,
href="mailto:tracy_lincoln@iroquois.com">tracy_lincoln@iroquois.com>
wrote in message
href="news:3C5B0F5C.3D12C290@iroquois.com">news:3C5B0F5C.3D12C290@iroquois.com...
href="http://support.autodesk.com/getdoc.asp?id=TS47474">http://support.autodesk.com/getdoc.asp?i...
DO NOT send
Tracy Lincoln
Index:
href="http://discussion.autodesk.com">http://discussion.autodesk.com
Rules:
href="http://discussion.autodesk.com/webx?groundrules">http://discussion.autodesk.com/webx?ground...
Product Support:
href="http://support.autodesk.com/">http://support.autodesk.com/
Knowledge Base:
href="http://support.autodesk.com/ViewAnswerworks.asp">http://support.autodesk.com/ViewAnswerwork...
Downloads:
href="http://support.autodesk.com/Downloads.asp">http://support.autodesk.com/Downloads.asp
Accurate wrote:
size=-1>I have SP2 Installed. Unless when I did a reinstall to correct
files (not an uninstall), it may have deleted or changed some of the files
from the service pack. Does anyone know whether when you do a
reinstall, do you have to also reinstall all of the service packs and
plotter upgrades as well?
color=#0000ff>Thanks
