Well, I tried to re-install ADT without uninstall it previously, and in the
second dialog box I chose "ripara caricamento di AEC" (repair AEC loading).
Then I tried to run some rendering, and everything seemed to be OK.
Have I found the right way to face this problem?
Thank you very much....
Daniele Biffino
Viale del Tramonto, 3
74010 Statte (TA)
"Shaan Hurley" ha scritto nel messaggio
news:15543753A62A11AFE68104F710485D1A@in.WebX.maYIadrTaRb...
> It sounds like something happened to the file or your installation on
> Saturday or Sunday but you are unsure of exactly what. I am not certain
if
> reinstalling or using the Add/Remove Repair option would solve this as I
> have not seen this specific error.
> Sincerely,
> Shaan Hurley
> Platform Technologies Group
> Autodesk, Inc.
> "Daniele Biffino" wrote in message
> news:EB54E8FE9AF0EFB8A94AC3A2A2A3163B@in.WebX.maYIadrTaRb...
> > > ADT stands for Architectural Desktop which is what you mentioned you
> were
> > > using. I am not sure what else could be causing this. When did it
start
> > and
> > > have you imported data from other applications into the file?
> > No, I worked till saturday in the evening and everithing was OK. Sunday
in
> > the morning this trouble come out as soon as I tried to run the first
> > rendering, after having changed some material maps (I usually use to map
> > materials with JPG images). The file was exactly the same, I did not add
a
> > single line since the day before, only created and saved new views and
> > changed material maps. Sunday I succeded in solve the situation by using
> the
> > step by step procedure I described before, and only "lost" a layer
> material
> > (in other words I discovered that render would run without problems if I
> > turned the "general_matte" layer off, or if I detached the material map
> from
> > it).
> > But today I had the some trouble, and I was forced first to erase some
> > objects (blocks) and then to detach the material map from other layers,
> and
> > in spite of this I can not have renderings, anyway!
> > Well, could I have any result if I completely uninstall Architectural
> > Desktop and install the software again?
> > Thank you....
> > Daniele Biffino
> > 74010 Statte (TA)
