AutoCAD 2000/2000i/2002 Archive
*Wally
Message 1 of 7 (142 Views)
Transparent viewport?
142 Views, 6 Replies
12-02-2002 06:38 PM
How can I make viewports in paperspace transparent? I'd like to put text and
lines over the viewports, but the annotations aren't visible on-screen
unless I select them. However, they are visible when I print. I've tried
bring the annotations to front, and sending the viewports to back, but this
doesn't seem to make any difference, and neither does changing the z-coords
of the respective objects.
Distinguished Contributor
jlaidler
Message 2 of 7 (142 Views)
Re: Transparent viewport?
12-02-2002 08:19 PM in reply to: *Wally
Place your viewports on the defpoints layer.
*Wally
Message 3 of 7 (142 Views)
Re:
12-02-2002 08:54 PM in reply to: *Wally
"jclaidler" wrote in message
This doesn't seem to make any difference. The following is leaving me
wondering what is going on...
Working on a new drawing, I went to the default layout for the first time,
to prepare to do a preliminary plot. The only thing I changed was the paper
size, from A4 to A1. The default viewport was created on the current layer -
a layer that I had created. Just for the hell of it, I decided to see what
would happen when a drew a line, in paper space, over the viewport. Lo and
behold, the line is visible through/over the viewport. Even if I change the
layer that the viewport and/or line is on, the line remains visible.
Now, here's the odd bit - the line disappears behind some of the drawing
elements in model space (eg, a solid hatch). The line is definitely in paper
space, as is the viewport (white background), and the rest of the drawing is
in model space (black background).
Weird...
*coogan, eric
Message 4 of 7 (142 Views)
Re:
12-03-2002 07:10 AM in reply to: *Wally
do you have print paperspace objects last checked on the plot settings
screen menu
"Wally" wrote in message
news:smileyvery-happy:5C5EFB794810699FE27513BB7812F2A@in.WebX.maYIadrTaRb...
paper
layer -
the
paper
is
> Weird...
*robfowler
Message 5 of 7 (142 Views)
12-03-2002 07:35 AM in reply to: *Wally
Make the viewport active in the layout and set SHADEMODE to 2D to make the
viewport transparent.
Rob Fowler.
news:05D2D77E8059A0CBB6EA1E4B5081A957@in.WebX.maYIadrTaRb...
and
this
z-coords
*johnosn, dc
Message 6 of 7 (142 Views)
12-03-2002 07:37 AM in reply to: *Wally
try this
go to options>system tab>layout regen options> and check regen when switching
layouts.
Dave C. Johnson
WWC Engineering
Sheridan WY.
Windows 2k
Acad Map 5
Survcadd XML
remove OUT to reply
*Wally
Message 7 of 7 (142 Views)
Re:
12-03-2002 05:05 PM in reply to: *Wally
"robfowler" wrote in message
Folks,
Thanks for the replies. Rob's solution, above, produces exactly what I'm
looking for. :-)
Wally
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
