AutoCAD 2000/2000i/2002 Archive (Read Only)
Transparent viewport?
6 REPLIES 6
717 Views, 6 Replies
How can I make viewports in paperspace transparent? I'd like to put text and
lines over the viewports, but the annotations aren't visible on-screen
unless I select them. However, they are visible when I print. I've tried
bring the annotations to front, and sending the viewports to back, but this
doesn't seem to make any difference, and neither does changing the z-coords
of the respective objects.
6 REPLIES 6
jlaidler
Place your viewports on the defpoints layer.
"jclaidler" wrote in message
This doesn't seem to make any difference. The following is leaving me
wondering what is going on...
Working on a new drawing, I went to the default layout for the first time,
to prepare to do a preliminary plot. The only thing I changed was the paper
size, from A4 to A1. The default viewport was created on the current layer -
a layer that I had created. Just for the hell of it, I decided to see what
would happen when a drew a line, in paper space, over the viewport. Lo and
behold, the line is visible through/over the viewport. Even if I change the
layer that the viewport and/or line is on, the line remains visible.
Now, here's the odd bit - the line disappears behind some of the drawing
elements in model space (eg, a solid hatch). The line is definitely in paper
space, as is the viewport (white background), and the rest of the drawing is
in model space (black background).
Weird...
do you have print paperspace objects last checked on the plot settings
screen menu
"Wally" wrote in message
news:D5C5EFB794810699FE27513BB7812F2A@in.WebX.maYIadrTaRb...
paper
layer -
the
paper
is
> Weird...
Make the viewport active in the layout and set SHADEMODE to 2D to make the
viewport transparent.
Rob Fowler.
news:05D2D77E8059A0CBB6EA1E4B5081A957@in.WebX.maYIadrTaRb...
and
this
z-coords
try this
go to options>system tab>layout regen options> and check regen when switching
layouts.
Dave C. Johnson
WWC Engineering
Sheridan WY.
Windows 2k
Acad Map 5
Survcadd XML
remove OUT to reply
"robfowler" wrote in message
Folks,
Thanks for the replies. Rob's solution, above, produces exactly what I'm
looking for. 🙂
Wally
