AutoCAD 2000/2000i/2002 Archive (Read Only)
Support Path Losing Entries
2 REPLIES 2
maguire
1380 Views, 2 Replies
For some reason which I have not been able to
figure out, I'm losing support path entries.
I have many custom programs that need to be
pathed to their respective directory locations
in the "TOOLS" "OPTIONS" "SUPPORT PATH" area.
I'll setup the pathing I need, and all my programs
will work fine, then for no apparent reason I'll
click on one of my program pulldown menus and
click on one of its functions and autocad will
tell me it can not find the file.
If I goto the "tools" "options" "support path"
area, I notice that part of the pathing I setup
is now gone. If I re-add the missing paths,
my programs again work fine.
Does anyone know why Autocad is truncating my
support path settings?
Is there some kind of limit to how many path
settings you can have?
Note: running autocad w/ LDDR2i
thanks for any advice on this matter!
2 REPLIES 2
pcboudreau
in reply to: maguire
Are you using a profile? I'm finding that some machines don't support profiles properly. How many characters are in your paths? What OS are you using?
Phil Boudreau
durielk
I have the same problem, did you find a solution?  thanks, dlkruger2000@yahoo.com
