AutoCAD 2000/2000i/2002 Archive
New Member
calgarykevvy
Message 1 of 3 (4,505 Views)
Solved: AutoCAD 2002 Mechanical Desktop 6.0 on Windows 7
4505 Views, 2 Replies
04-07-2010 10:38 PM
Hi All;
Had a problem with Acad 2002/MDT 6.0 crashing on Windows 7. Saw a number of posts in this forum and all over the internet that seemed unsolved.
Was getting an error something like Unhandled Exception C++ Library.
Tracked it down to being a printing problem. Acad would print and run no problem. Could even close the program and launch it again as long as the machine wasn't restarted. When the machine was re-booted Acad crashed right after the template was loaded.
The only fix I found was to enable the Administrator account and run Acad from there. Note the account created when Win 7 was installed has administrator privileges but it is not the same as the sys admin. To enable the Administrator account:
- go to the Start Menu/All Programs/Accessories and RIGHT CLICK on Command Prompt.
- click on Run As Administrator (click Yes to run)
- type:
net user administrator /active:yes (hit enter, will confirm if successful)
- go to Control Panel/User Accounts/Manage Another Account
- the administrator account should show and you can set the password
- log off and then on as Administrator with the password you just set
- Win 7 will create your desktop and your AutoCAD installation should be there
- launch AutoCAD and test
Mine ran under the Administrator account even though it was crashing in my user account. Anyway, I fought with this for a long time and this worked for me. If you run into any troubles with the Windows setup procedures, just Google the topic before asking questions. It's where I learned. The only thing I contributed is actually trying to run logged in as Administrator.
No idea if it works for other versions of AutoCAD.
Good luck!
Kev
New Member
AdamG8GXP
Message 2 of 3 (4,191 Views)
Re: Solved: AutoCAD 2002 Mechanical Desktop 6.0 on Windows 7
05-02-2011 12:28 PM in reply to: calgarykevvy
Thanks. :manhappy: That worked for my Autocad 2002. I was getting "FATAL ERROR: unhandled e06d7363h Exception at 7500b760h" error and crash right after starting Autocad.
I am running Windows 7 Pro 32 Bit.
New Member
drvyts
Message 3 of 3 (4,043 Views)
06-06-2011 04:02 AM in reply to: calgarykevvy
doesn't work on MDT 2009
Announcements
Need installation help?
