AutoCAD 2000/2000i/2002 Archive (Read Only)
Software to create Bill of Material
8 REPLIES 8
Message 1 of 9
216 Views, 8 Replies
any outthere with good functionality?
8 REPLIES 8
Message 2 of 9
the bill of material is for strucural steel work.
using acad2k2 and win2k
wally
Message 3 of 9
Try searching through the Partner's site:
http://partnerproducts.autodesk.com/catalog/default.asp
Please, DO NOT send technical requests to me via private e-mail
Tracy Lincoln
Assistant Moderator, Autodesk Discussion Groups
Discussion Group Links:
Index: http://discussion.autodesk.com
Rules: http://discussion.autodesk.com/webx?groundrules
Product Support: http://support.autodesk.com/
Knowledge Base: http://support.autodesk.com/ViewAnswerworks.asp
Downloads: http://support.autodesk.com/Downloads.asp
Message 4 of 9
and that's a bunch of garbage, isn't it?
Message 5 of 9
? Garbage ?
There are Steel Detailing packages, there are Bill of Material packages
and then there are a few that combine these features... is that not what
you asked for?
AutoCAD Mechanical, Mechanical Desktop and Inventor all have these
capabilities... if you choose to stick with generic AutoCAD you will
need to customize it.
There are also some 3rd Party applications that are available if you
search the internet via a decent search engine.
Tracy Lincoln
Message 6 of 9
Hey now, I'm listed up there. 🙂
Seriously, what *exactly* are you trying to achieve?
Terry
Message 7 of 9
well, it was an off-the-cuff comment; which i suppose i should be sorry for. But i looked at the reference and it is not much. . . poorly organized and with none of the good stuff, like dotsoft.
Message 8 of 9
i have strucpro which does attempt at a bom. But i need one for structures. I solved my problem with dotsoft xl2cad.exe.
Message 9 of 9
Multisuite is good software for bill of material
