AutoCAD 2000/2000i/2002 Archive
kylegoltsch
Message 1 of 6 (688 Views)
simple dxf file 8 mb
688 Views, 5 Replies
07-30-2011 08:30 AM
i have about 12,000 dxf files and some are simple parts with 3 lines, 1 hole and i line of simple text.  the file is 8,126 kb.  I know this is huge.  i have purged everything and tried wblock, picked each individual object and inserted into a new file.  same result.  i cannot figure out how to reduce the size.  there is something hidden that i cannot find.  i have attached a file for anyone to view.  any help will be appreciated.  i zipped the file because the autodesk web site would not let me post it.
Found out it was the layer filters.  Must have been near a thousand on some files.  Found the lsp file lfd.lsp on another site.  It deletes all the layer filters.  Files are now in the area of 22 kb.
azrdgldr
Message 2 of 6 (678 Views)
Re: simple dxf file 8 mb
07-30-2011 02:37 PM in reply to: kylegoltsch
I reduced it by a little bit, very little bit.  I removed unused dimstyle and text styles.  I searched for blank text and found nothing.  I would say it is the way it is.
Employee
artc2
Message 3 of 6 (675 Views)
07-30-2011 10:37 PM in reply to: kylegoltsch
The vast majority of the file is in dictionaries and xrecords.  It looks like architectural data because there are strings such as "(structural plan)" and "fireplace walls" and "___DEMOLITION" and "___ARchitecture".
kylegoltsch
Message 4 of 6 (660 Views)
08-01-2011 10:34 AM in reply to: kylegoltsch
New Member
norkghadsk
Message 5 of 6 (614 Views)
11-01-2011 08:20 AM in reply to: kylegoltsch
hello how do i run autodesk 2002 on windows(7) seven
after installation everything comes but the design which contains wall is not shown.
it reads as a fatal error thanks Norris
kylegoltsch
Message 6 of 6 (610 Views)
11-01-2011 09:41 AM in reply to: norkghadsk
