AutoCAD 2000/2000i/2002 Archive (Read Only)
Shift Deselect is Not Working
5 REPLIES 5
1504 Views, 5 Replies
Hi All
I support 50 ACAD 02 users and one came to me today saying he can no longer use the shift key to deselect. I thought this had something to do with the file he was working on but a new file had the same problem. Is there a system varable to control this? Thanks in advance
Mike Ostrouch
AutoCAD Support
Lockheed-Martin
Syracuse NY
5 REPLIES 5
PICKADD?
"lmco_syracuse" wrote in message
news:f12304f.-1@WebX.maYIadrTaRb...
> Hi All
> Mike Ostrouch
> AutoCAD Support
> Lockheed-Martin
> Syracuse NY
I tried pick add and that was not it.
Go to the "options" window and pick the selection tab, on the left side, is there a check mark in use shift to add?
This has to have a check mark or the value of PICKADD must be set to zero.
Hi All, and thanks for your input but I found the problem. When Raster Design 3 is loaded on top of AutoCAD 2002 SP1 the Shift Deselect does no longer work. Something in the Raster Design 3 package seems to disable this.
Mike Ostrouch
Mike, while in Raster select the raster tools tab on the ribbon - select the angled arrow on the insert 7 write panel to open the Raster Design options dialog box - select the User Preferences dialog box and deselect the "Shift+Left Click image select" box and hit OK.
