AutoCAD 2000/2000i/2002 Archive (Read Only)
scale: can i scale an object in one axis?
3 REPLIES 3
2226 Views, 3 Replies
I wonder if I can scale an object in one axis? 3DMax can do it, but In cad, I only can scale down an object from two axis.
3 REPLIES 3
No. But you can insert it as block and scale the insertion with three different scale factors. Juergen SMR schrieb: > > I wonder if I can scale an object in one axis? 3DMax can do it, but In cad, > I only can scale down an object from two axis.
If you make a block of the objects then you can insert at non-uniform scales (and also adjust in any of the 3 axis). -- Tracy W. Lincoln Autodesk Discussion Group Facilitator http://www.autodesk.com/discussion-announcements "SMR" wrote in message news:404b2be1$1_1@newsprd01... > I wonder if I can scale an object in one axis? 3DMax can do it, but In cad, > I only can scale down an object from two axis. > >
The OBJECT has to be a block (you can make it so temporarily if needed), then PROPERTIES command can handle the task. -- Dean Saadallah Add-on products for LT http://www.pendean.com/lt --
