Next time you start AutoCAD, start a new drawing using that template.
Tip: Use an _underscore for the name of the template and it will show
up at the top of the list.
Another Tip: DesignCenter (CTRL+2 or ADCENTER or ADC) will allow you
to drag-n-drop Text Styles, Dimension Styles (and other things like
Layers, block, etc.) from any existing drawing)
Please, DO NOT send technical requests to me via private e-mail
Tracy Lincoln, Assistant Moderator
Autodesk Discussion Groups Forum Moderator Program
Discussion Group Links:
Index: http://discussion.autodesk.com
Rules: http://discussion.autodesk.com/webx?groundrules
Product Support: http://support.autodesk.com/
Knowledge Base: http://support.autodesk.com/ViewAnswerworks.asp
Downloads: http://support.autodesk.com/Downloads.asp
