You can trim a "true ellipse" in half, then create the region with the line
and the half ellipse. This method doesn't leave all the lines on the
revolved solid.
Tim Storey
"Bernd Hoffmann" wrote in message
news:Xns92346C229E22Ephantomdrafter@64.124.46.110...
> jbryant4 wrote in
> news:f0ecfd2.3@WebX.maYIadrTaRb:
> > It works only if you revolve it around a oint that is not within the
> > ellispe. I think what he is asking, is can you revolve it about its
> > own C'line, which you can't do. Attachment decoded: untitled-1.html
> Yes you can. First set the variable PELLIPSE = 1 so the ELLIPSE command
> draws polylines instead of true ellipses. Draw a line through the center,
> TRIM off half of the ellipse. Make a REGION or (PEDIT, Join) the line and
> the ellipse arc. Then you can REVOLVE. Oh my a flying saucer! 🙂
> Regards, Bernd
> Designer
> Burris Savvy Optics
> http://www.burrisoptics.com/
