AutoCAD 2000/2000i/2002 Archive (Read Only)
resident objects...?
2 REPLIES 2
184 Views, 2 Replies
I have a number of objects that are on layer X, at least according to the properties dialog box, however if I turn all of the layers except layer X off there are no objects visible. The objects on layer X seem to be connected to layer Y, when I turn just layer Y on the objects on layer X appear.What's up? Is there anyway to fix this?
v
2 REPLIES 2
Possibly Blocks defined on Layer Y but inserted in Layer X?
DO NOT send technical requests to me via private e-mail
Tracy Lincoln
Assistant Moderator, Autodesk Discussion Groups
Discussion Group Links:
Index: http://discussion.autodesk.com
Rules: http://discussion.autodesk.com/webx?groundrules
Product Support: http://support.autodesk.com/
Knowledge Base: http://support.autodesk.com/ViewAnswerworks.asp
Downloads: http://support.autodesk.com/Downloads.asp
> v
You must redefine the block, with all entities placed on layer 0, and no other layers existing other than 0.
