AutoCAD 2000/2000i/2002 Archive (Read Only)
terryrepol
142 Views, 3 Replies
Rectangles
All of a sudden my rectangle icon says "_rectang Unknown command "RECTANG" . Press F1 for help.
Do you think someone could help me figure out where this disappeared or how to repair???
Typing in rec, rectang or using the drop down menu brings me the same result.
Terry Repol
3 REPLIES 3
in reply to: terryrepol
"All of a sudden" as in after you loaded your own custom menu file? You need
a copy of the ACAD.MNL file with the same name as your menu file present.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
terryrepol
Dean: Thanks for your reply but I have not added any custom menus. Just recently reloaded the program and customized my icon groups, nothing more.
Terry
Is DEMANDLOAD set to 3 ?
Please, DO NOT send technical requests to me via private e-mail
Tracy W. Lincoln
Assistant Moderator - Autodesk Discussion Forums
Discussion Group Links:
Index: http://discussion.autodesk.com
Rules: http://discussion.autodesk.com/webx?groundrules
