I'm using Qleader with Mtext, and I have the "Settings" options set for middle of top line. The text comes in just fine, and will re-associate correctly upon moving the text, UNLESS I cross the leader point. In other words, if I move the text from left side of labeled object to right side. When I do that, the alignment is set back to middle of multi-line text. The settings don't change, and new placements come in correctly, but the "moved" text can't be updated to what it should be. Happens on all computers, all drawings, Any clues?
