AutoCAD 2000/2000i/2002 Archive (Read Only)
Properties window for text
14 REPLIES 14
Message 1 of 15
264 Views, 14 Replies
I am trying to change the style of text from the properties window. It shows in the help file that if I select a text object and then click on the properties tab, then I should be able to change certain features of the text(i.e. style, justify, contents, etc.) But when the properties window pops up there is not a category for the text properties. Am I missing something in my options setup and how can I fix this problem? I know I can change the style by using the command line, but that is cumbersome and takes a long time. It sure would be nice to be able to change it from the properties window. Please help.
14 REPLIES 14
Message 2 of 15
jlaidler
Do you have just text objects gripped ??
Message 3 of 15
yes
Message 4 of 15
jlaidler
In the properties window, does it say 'text' at the very top ??
Message 5 of 15
yes
Message 6 of 15
jlaidler
Then there should be a 'text' area in the properties window.
Message 7 of 15
But there isn't. The only categories that I have are general and geometry. Weird huh?
Message 8 of 15
jlaidler
There isn't a 'mics' category ?? Are the categories minimized ??
Message 9 of 15
No there is not a misc category. And they are not minimized.
Message 10 of 15
I do notice that if I click on multiline text that it gives me the ability to change the text properties for it? I wonder why it won't give me that ability for sinle line text?
Message 11 of 15
You'll have to post a sample file with this text for someone to explore:
Customer Files area is the appropriate posting place.
Dean Saadallah
Add-on products for LT
http://www.pendean.com
LT Express Utilities
http://www.pendean.com/ltexpress
Message 12 of 15
bludwick
I'm having a simlar issue with the justify property not being included in the propeties window. Any help would be appreciated.
Message 13 of 15
I have this 'Reset Properties Window' macro:
^C^Carx;u;acopm;properties;
on a custom button because I'm always losing fields in the properties box.
Try typing:
arx u acopm
and then trying properties again. If that fixes things it might be worth
setting yourselves up a similar button.
"bludwick" wrote in message
news:f158914.10@WebX.maYIadrTaRb...
Message 14 of 15
bludwick
Thanks for the responce. Unfortunatly it did not help. Any other suggestions?
Message 15 of 15
can you create the new text style then go to property text window.
