AutoCAD 2000/2000i/2002 Archive (Read Only)
157 Views, 3 Replies
PLOT LOGS
Does anyone know how to disable the plot logs? Thanks.
3 REPLIES 3
go to your plot dialogue>plot device tab>setting (under plot stamp)>advanced
(bottom left corner) and uncheck create a log file
Dave C. Johnson
WWC Engineering
Sheridan WY.
Windows 2k2
Acad Map 5
Survcadd XML
The original of this message with attached 3.5meg file has been
moved to the Customer Files area
(news://discussion.autodesk.com/autodesk.autocad.customer-files
or http://discussion.autodesk.com/WebX?14@@.ee940b5). PLEASE do
not post files into technical support groups. Zipping files is a
courtesy to those who download them.
See the newsgroup guidelines at
http://discussion.autodesk.com/webx?groundrules.
Anne Brown
Manager, Moderator
Autodesk Product Support discussion groups
Discussion Q&A: http://www.autodesk.com/discussion
Subject:
Re: PLOT LOGS
Date:
Fri, 7 Mar 2003 13:32:39 -0800
"Maria Monroy"
Newsgroups:
autodesk.autocad.2002general
This is what I get I can't access that window.
File: win.bmp
If you cannot access the dialog box then your PSS file is read-only or
corrupt. Do a search for "PSS" in this newsgroup and you will find more
info/help.
Greg
"Maria Monroy" wrote in message
news:f14c251.-1@WebX.maYIadrTaRb...
