AutoCAD 2000/2000i/2002 Archive (Read Only)
Order of attribute tags
1 REPLY 1
162 Views, 1 Reply
Probably an easy question-
I have an attributed block, and I want to change the order of the
attributes.Batman also won't solve the order problem - as it only changes
the order once the block is inserted.
How can I do this without having to recreate the block again?
thanks Russ
1 REPLY 1
With BATTMAN, you have to WBLOCK the block from the drawing with the
attributes reordered. Some have said that this reverses the order
desired, so if that is the case, order them in reverse using BATTMAN
before WBLOCKing.
You can also search for a file called ATTORD.LSP which will do this.
Ian A. White, CPEng
WAI Engineering
Sydney 2000
Australia
Ph: +61 418 203 229
Fax: +61 2 9622 0450
Home Page: www.wai.com.au
