changing them to overlays works perfect, thank you
MTB
"murrayc" wrote in message
news:2314224.1075923620116.JavaMail.javamailuser@localhost...
> If I understand correctly, you are currently in "DRAWING-A", and you want
to XREF in "DRAWING-B", but "DRAWING-B" has drawings "C" & "D" attached as
well which you don't need.
> Here's what to do....
> 1.Open "DRAWING-B"
> 2.Enter the XREF command which opens the dialog box (ie XREF Manager)
> 3.While in the XREF Manager, click on the xref for "DRAWING-C" to make it
active
> 4.Under the TYPE column, double-click on the word ATTACH and it will
change to OVERLAY.
> 5.Do this again for the xref "DRAWING-D"
> 6.Save "DRAWING-B"
> 7.Go to "DRAWING-A" and reload the xref "DRAWING-B"
> Hope this answers your question. If not, what I explained always makes a
good tip.
> Murray C
