Show only
Search instead for
I am using cad 2002. I need to add a logo (tif image) to a water storage tank surface. the tank is shaped with a cylindrical section sandwiched between two elliptical domes. I can get the cylinder solid. How do i get a elliptical solid with a surface? How do i add the tif image to the surface? Thanks.
Dear DALDaver
Thanks for the tips. I was not able to revolve the section of the ellipse, however I was able to fit an arc close enough to get the perspective we wanted. I also managed to overlay the 3D tank with new logo onto a photo of the existing tank. Again Thanks!!!
you cant actually revolve an ellipse. what you need to to do is use a circle with a short straight face at one of the quadrants. ensure that you have a quarter of the circle closed and then revolve it..
Tell me again why you can't revolve an ellipse? Seems to work for me.
wrote in message news:4862843@discussion.autodesk.com...
Use BOUNDARY to create a new REGION of the area you wish to revolve. My
guess is you've used a true ELLIPSE, which can not be turned into a pline.
wrote in message news:4865893@discussion.autodesk.com...
well im using 2002 and i cant seem to do a pedit to close the elipse.
therefore i cant revolve it..
