AutoCAD 2000/2000i/2002 Archive (Read Only)
mtext is changing font
3 REPLIES 3
306 Views, 3 Replies
Every time I edit an mtext box my font changes to Tahoma. All the settings for the mtext box are correct to our standards and which is not Tahoma. The same happend in the dimention edit box. We cannot find a setting that alows us to make this not happen.
Has anyone had this happen?
How can I fix it?
Dale Wierenga
3 REPLIES 3
Note the webpage location, use that next time for a search before posting, most basic questions are answered there: http://usa.autodesk.com/adsk/servlet/ps/kb?la=en&siteID=123112&id=2334116&linkID=2475323&col=support&qt=tahoma&qp=%2Bsiteid%3A123112&qp=+%7C+PROD%3A10310+%7C+&qp=%2BPRODC%3A2475145&lk=1&st=1&rq=0 or http://tinyurl.com/3s8b2 Post back if that does not fix it. -- Dean Saadallah Add-on products for LT http://www.pendean.com/lt --
mtproxy1.ttf thru mtproxy9.ttf are missing from your \windows\fonts folder. You need to get them back. "DaleWWW" wrote in message news:12947337.1094839646129.JavaMail.jive@jiveforum1.autodesk.com... > Every time I edit an mtext box my font changes to Tahoma. All the settings for the mtext box are correct to our standards and which is not Tahoma. The same happend in the dimention edit box. We cannot find a setting that alows us to make this not happen. > Has anyone had this happen? > How can I fix it? > > Thanks > Dale Wierenga
thank you, that did it.
