AutoCAD 2000/2000i/2002 Archive
Anonymous(anon)
Message 1 of 8 (169 Views)
moving an object from Model Space to Paper Space
169 Views, 7 Replies
05-24-2004 08:05 AM
*Paul Turvill
Message 2 of 8 (169 Views)
Re: moving an object from Model Space to Paper Space
05-24-2004 08:05 AM in reply to: Anonymous
Express Tools: CHSPACE ___ wrote in message news:40b200ea$1_2@newsprd01... > Does anyone know if AutoCad 2002 has a command that will allow you to move an object from model space to paper space?
Distinguished Contributor
madcadd
Message 3 of 8 (169 Views)
05-24-2004 08:47 AM in reply to: Anonymous
If you do not have the necessary tool, try;
Copy and Paste entire view...or
Block and insert entire view...or
Wblock entire view...............GL
sandymouldin
Message 4 of 8 (169 Views)
05-24-2004 08:53 AM in reply to: Anonymous
Hi Madcadd,
If the zoom is not 1xp will this be possible?
Message was edited by: sandra
madcadd
Message 5 of 8 (169 Views)
05-24-2004 09:30 AM in reply to: Anonymous
Hi sandra,
Zoom 1xp would not matter, only changing the scale would. If it is drawn full (as it should always be) scale, it will be full scale in the new drawing where you locate it and you can do with it as you please once there.
Whatever layers are on, whatever fonts are used, whatever everything that is included in your "capture" will be what you get in the new location.
jackshield
Message 6 of 8 (169 Views)
05-24-2004 12:20 PM in reply to: Anonymous
does the "zoom 1xp" apply to all of paper space, or just a viewport?
Member
CAD_RJM
Message 7 of 8 (169 Views)
05-25-2004 11:06 AM in reply to: Anonymous
In your paperspace view, select the objects you want to change over.
After selecting the objects to be changed, Go to the "EXPRESS" pull down and pick "LAYOUT TOLLS".
Choose the CHANGE SPACE ms/ps and press the enter key.
madcadd
Message 8 of 8 (169 Views)
05-25-2004 11:37 AM in reply to: Anonymous
Reply From: jackshield
Date: May/24/04 - 14:20 (CDT)
jack,
"Zoom 1xp" is to bring your "Layout (floating) MS" up to Full scale. You are scaling it to PS. You don't use it in PS or "Model (tiled) Space". And if your drawing doesn't fit on the screen after 1xp, then you have to scale up or down until it does. I've explained this in many other threads. I'd be surprised if you haven't read them all.
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
