AutoCAD 2000/2000i/2002 Archive (Read Only)
moving an object from Model Space to Paper Space
7 REPLIES 7
Message 1 of 8
424 Views, 7 Replies
7 REPLIES 7
Message 2 of 8
Express Tools: CHSPACE ___ wrote in message news:40b200ea$1_2@newsprd01... > Does anyone know if AutoCad 2002 has a command that will allow you to move an object from model space to paper space?
Message 3 of 8
If you do not have the necessary tool, try;
Copy and Paste entire view...or
Block and insert entire view...or
Wblock entire view...............GL
Message 4 of 8
Hi Madcadd,
If the zoom is not 1xp will this be possible?
Message was edited by: sandra
Message 5 of 8
Hi sandra,
Zoom 1xp would not matter, only changing the scale would. If it is drawn full (as it should always be) scale, it will be full scale in the new drawing where you locate it and you can do with it as you please once there.
Whatever layers are on, whatever fonts are used, whatever everything that is included in your "capture" will be what you get in the new location.
Message 6 of 8
does the "zoom 1xp" apply to all of paper space, or just a viewport?
Message 7 of 8
In your paperspace view, select the objects you want to change over.
After selecting the objects to be changed, Go to the "EXPRESS" pull down and pick "LAYOUT TOLLS".
Choose the CHANGE SPACE ms/ps and press the enter key.
Message 8 of 8
Reply From: jackshield
Date: May/24/04 - 14:20 (CDT)
Re: moving an object from Model Space to Paper Space
jack,
"Zoom 1xp" is to bring your "Layout (floating) MS" up to Full scale. You are scaling it to PS. You don't use it in PS or "Model (tiled) Space". And if your drawing doesn't fit on the screen after 1xp, then you have to scale up or down until it does. I've explained this in many other threads. I'd be surprised if you haven't read them all.
