AutoCAD 2000/2000i/2002 Archive
*Dennis Rich
Post 1 of 8
Modifying commands
93 Views, 7 Replies
08-25-2005 09:15 AM
I was wondering if there is a way to modify certain commands within Autocad.
For instance, drawing a line, I usually keep node snaps turned on but
nothing else. Is it possible to draw the line and instead of picking the
endpoint snap manually, type in E for endpoint and have it snap this way.
Any help would be appreciated.
Dennis Rich
D.T. Collins & Associates
1042 Mechem Drive
Ruidoso, NM 88345
(505) 258-5272
1 Kudo
Post 2 of 8
Re: Modifying commands
08-25-2005 10:11 AM in reply to: *Dennis Rich
You can TAB mid-command and it will select & cycle through the nearest
osnaps.
Hope this helps!
Hope this works.
"Dennis Rich" wrote in message
news:4938855@discussion.autodesk.com...
Dennis Rich
1042 Mechem Drive
Ruidoso, NM 88345
(505) 258-5272
*R.K. McSwain
Post 3 of 8
08-25-2005 11:11 AM in reply to: *Dennis Rich
You could undefine the core "line" command, then use your own lisp routine
to
draw lines with ENDP object snap turned on (example below):
(defun c:line ()
(setq o (getvar "osmode"))
(setvar "osmode" 1)
(setq p1 (getpoint "\n Specify first point: "))
(setq p2 (getpoint p1 "\n Specify next point: "))
(setvar "osmode" 0)
(command "._line" p1 p2 "")
(setvar "osmode" o)
(princ)
R.K. McSwain
http://rkmcswain.blogspot.com
Distinguished Contributor
12 Kudos
Post 4 of 8
08-25-2005 12:12 PM in reply to: *Dennis Rich
Hi R. K.,
Is the highlighted "o" oh supposed to be "0", zero in your lisp routine?
12 Kudos
Post 5 of 8
08-25-2005 12:13 PM in reply to: *Dennis Rich
Opps! What highlight? ;-)
*R.K. McSwain
Post 6 of 8
08-26-2005 05:07 AM in reply to: *Dennis Rich
madcadd wrote:
> Hi R. K.,
No. It's the same "o" as in the second line.
R.K. McSwain
12 Kudos
Post 7 of 8
08-26-2005 11:20 AM in reply to: *Dennis Rich
OK! Just checkin' ;-)
Valued Contributor
0 Kudos
Post 8 of 8
09-01-2005 09:27 AM in reply to: *Dennis Rich
If you work without OSNAP turned on but still want to use snaps now ant then your can usually type in the first 3 or 4 letters of a snap point mid command. Eg:
END = ENDPOINT
PER = PERPENDICULAR
QUAD = QUADRANT.
etc.
Careful though, if you miss the first the first time you will have to type it in again.
Oh yeah, and you can toggle OSNAP with F3.
Cheers
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
