AutoCAD 2000/2000i/2002 Archive (Read Only)
Modifying commands
7 REPLIES 7
Message 1 of 8
291 Views, 7 Replies
Modifying commands
I was wondering if there is a way to modify certain commands within Autocad.
For instance, drawing a line, I usually keep node snaps turned on but
nothing else. Is it possible to draw the line and instead of picking the
endpoint snap manually, type in E for endpoint and have it snap this way.
Any help would be appreciated.
Dennis Rich
D.T. Collins & Associates
1042 Mechem Drive
Ruidoso, NM 88345
(505) 258-5272
7 REPLIES 7
Message 2 of 8
cadanator
You can TAB mid-command and it will select & cycle through the nearest
osnaps.
Hope this helps!
Hope this works.
"Dennis Rich" wrote in message
news:4938855@discussion.autodesk.com...
Dennis Rich
1042 Mechem Drive
Ruidoso, NM 88345
(505) 258-5272
Message 3 of 8
You could undefine the core "line" command, then use your own lisp routine
to
draw lines with ENDP object snap turned on (example below):
(defun c:line ()
(setq o (getvar "osmode"))
(setvar "osmode" 1)
(setq p1 (getpoint "\n Specify first point: "))
(setq p2 (getpoint p1 "\n Specify next point: "))
(setvar "osmode" 0)
(command "._line" p1 p2 "")
(setvar "osmode" o)
(princ)
R.K. McSwain
http://rkmcswain.blogspot.com
Message 4 of 8
madcadd
Hi R. K.,
Is the highlighted "o" oh supposed to be "0", zero in your lisp routine?
Message 5 of 8
madcadd
Opps! What highlight? 😉
Message 6 of 8
madcadd wrote:
> Hi R. K.,
No. It's the same "o" as in the second line.
R.K. McSwain
Message 7 of 8
madcadd
OK! Just checkin' 😉
Message 8 of 8
Cad Monkey 19
If you work without OSNAP turned on but still want to use snaps now ant then your can usually type in the first 3 or 4 letters of a snap point mid command. Eg:
END = ENDPOINT
PER = PERPENDICULAR
QUAD = QUADRANT.
etc.
Careful though, if you miss the first the first time you will have to type it in again.
Oh yeah, and you can toggle OSNAP with F3.
Cheers
