I don't quite understand the fix or the problem, but I kindof got it all to work.
After installing AutoCAD 2002 in its own folder, I then installed AutoCAD 2000 in
it's own folder. Now they both open and run fine, after spending an hour
reconfiguring each profile to search the same folders etc...
Sam_Hochberg wrote:
> what OS are you on? If it's '98 or a derivative, your problem is that your
> path is too long or incorrect somehow, in your autoexec.bat file. You have the
> right file, but the path statement isn't allowing acad to find it. Shorten/fix
> the path or load the software in a shorter directory structure.
> "Mike Edmiston" wrote in message
> news:3DA7163D.40B62229@deberryeng.com...
> > Trying to install CAD 2002. Install goes ok, but when I try to run
> > AutaCAD, it gives me an error saying it is missing file acge15.dll
> > Tried installing ontop of AutoCAD 2000, but then my registration code
> > doesn't work because it's using the wrong serial number and CD key. Any
> > ideas, or just e-mail me the acge15.dll file.
> > thanks
> > mike
