AutoCAD 2000/2000i/2002 Archive (Read Only)
Menu Load Failed
4 REPLIES 4
farzad
586 Views, 4 Replies
Menu Load Failed
Hi, I am experiencing few error messages when I start ACAD 2000 which read:
Menuload failed.file not found: dwggateway.(mnu/mns/mnc)
Menuload failed.file not found: toolbar.(mnu/mns/mnc)
Menuload failed.file not found: show.(mnu/mns/mnc)
After I close or press ESC to get rid of these windows one at a time then I find the ACAD is stuck on a pending command which I have to press ESC to free it up.
I have tried to un install and reinstall ACAD but it has not fix the problem.
Has anyone else experienced the same problem, if so I could use some help please.
4 REPLIES 4
in reply to: farzad
If you looked and read the error message.... It would seem
your installation of the DWGGATEWAY product is no longer
valid, uninstall it or reinstall and patch AutoCAD.
Don't know what that is? Ask the person that installed it
for you.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
in reply to: farzad
I have the exact same problem as "farzad".
Any one have a solution?
farzad
in reply to: farzad
I did try everything that they suggested, to be honest nothing worked, finally went to my add/remove program and REMOVED the DWG Gateway program form my list, rebooted and everything is alright now, with the exception of not having the DWG Gateway any longer, maybe you should try this.
Farzad
in reply to: farzad
farzad;
Thanks for the info.
Do you have SolidWorks on the same machine?
I do and I'm suspecting there might be a connection with these error messages.
