AutoCAD 2000/2000i/2002 Archive
*James Bertke
Message 1 of 3 (149 Views)
Materials library cannot find tga files
149 Views, 2 Replies
02-22-2004 11:39 AM
My materials library shows lots of material types but when I try to preview or import them It says it cannot find the *.tga files. I assume it is loking in the textures folder. I found the tga files in a "cab" file on the installation disk but attempts to extract them using Windows XP results in the message " Not enough storage is available to complete this operation". Can you help Thanks Jim B
*Dean Saadallah
Message 2 of 3 (149 Views)
Re: Materials library cannot find tga files
02-22-2004 05:24 PM in reply to: *James Bertke
Did you try a reinstall of AutoCAD? -- Dean Saadallah Add-on products for LT http://www.pendean.com/lt --
*Tracy W. Lincoln
Message 3 of 3 (149 Views)
02-22-2004 06:20 PM in reply to: *James Bertke
When you initailly installed, you probablly chose Typical vs. Complete -- ************************************************************** Please, DO NOT send technical requests to me via private e-mail ************************************************************** Tracy W. Lincoln Assistant Moderator - Autodesk Discussion Forum http://www.autodesk.com/discussion-announcements "James Bertke" wrote in message news:40390564_1@newsprd01... > My materials library shows lots of material types but when I try to preview > or import them It says it cannot find the *.tga files. I assume it is loking > in the textures folder. I found the tga files in a "cab" file on the > installation disk but attempts to extract them using Windows XP results in > the message " Not enough storage is available to complete this operation". > Can you help > Thanks > Jim B > >
Need installation help?
