AutoCAD 2000/2000i/2002 Archive (Read Only)
Layer Prefixing?
4 REPLIES 4
140 Views, 4 Replies
Layer Prefixing?
G'day All,
Has anyone got a routine for putting a prefix in front of all
layernames?
For example, adding EX for existing to the front of all layers in a
drawing.
Regards
Scott V
4 REPLIES 4
command: _rename
in the dialog box choose "layer"
old name: *
rename to: ex*
If you want to delete the prefix type this:
old name: ex*
rename to: *
HTH
Juergen
"Viney, Scott" wrote:
> G'day All,
> layernames?
> drawing.
> Regards
> Scott V
Sub chlayerprefix()
For Each ent In ThisDrawing.Layers
a = ent.Name
If ent.Name <> 0 Then
ent.Name = "Ex_" & CStr(a)
Next ent
End Sub
1. Copy the above lines
2. Hit ALT+F11
3. Insert > Module
4. Edit > Paste
5. File > Close and return to autocad
6. Hit ALT+F8
7. Click Run button.
Good Luck,
Madhanagopal
AutoCAD & MCAD Product Support, INDIA
WW Support & Services, Autodesk
Discussion Q&A: http://www.autodesk.com/discussion
"Jürgen Palme" wrote in message
news:3B16255E.D77793A7@debitel.net...
> command: _rename
> old name: *
> rename to: ex*
> old name: ex*
> rename to: *
> HTH
> Juergen
> > G'day All,
> > layernames?
> > drawing.
> > Regards
> > Scott V
Thanx for the help,
I was trying to do this with the command line version, which (EDITED) when using a * for the OLD NAME
Cheers
Scott V
> G'day All,
> layernames?
> drawing.
> Regards
> Scott V
FYI
You can change any prefix by modifying the following line in that
program
color=#008000>'**********************************************
Sub
chlayerprefix()
a = ent.Name
If
ent.Name <> 0 Then
'Old name
"Ex_"
'ent.Name = "Ex_" & CStr(a)
'New Name "A"
ent.Name =
color=#ff0000>"A"
& CStr(a)
Next ent
End
Sub
color=#008000>'************************************************
Madhanagopal
WW Support
Discussion Q&A:
href="http://www.autodesk.com/discussion">http://www.autodesk.com/discussion
Thanx for the help,
Cheers
> Scott V
> > G'day All,
> > layernames?
> > For
drawing.
> > Regards
> > Scott
V
