AutoCAD 2000/2000i/2002 Archive (Read Only)
Is there a way to turn meshes or 3D Faces into solids
3 REPLIES 3
225 Views, 3 Replies
Can someone please help.
Is there a way to turn meshes or 3D Faces into solids. I have a model with
both solids and 3D faces that I need to project into 2D. I have been using
SOLFROF but it only works with solids.
The model I have that is made of 3D faces is a cone that is curved and with
an offset apex. I’m not sure how to create this model as a solid..
I have AutoCad 2000. Any help would be much appreciated.
Regards
Rob Pickers
pickcadd@sai.co.za
3 REPLIES 3
TRY WMFOUT and WMFIN commands
Madhanagopal
AutoCAD & MCAD Product Support, INDIA
WW
Support & Services, Autodesk
Discussion Q&A:
href="http://www.autodesk.com/discussion">http://www.autodesk.com/discussion
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Regards
Rob Pickers
pickcadd@sai.co.za
I would like to turn the 3D faces into solids.
WMFOUT will turn them into 2D. I have just found out that if I extrude the 3D
faces they will then turn into solids.
Rob
style="BORDER-LEFT: #000000 2px solid; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px; PADDING-LEFT: 5px; PADDING-RIGHT: 0px">
Madhanagopal
INDIA
WW Support & Services, Autodesk
Discussion Q&A:
with both solids and 3D faces that I need to project into 2D. I have been
using SOLFROF but it only works with solids.
with an offset apex. I’m not sure how to create this model as a solid..
Regards
Rob Pickers
pickcadd@sai.co.za
Rob Pickers,
I thought, you wanted to get a 2D from 3D surfaces. I am not aware of
converting surfaces into solids in AutoCAD but this is possible in Mechanical
Desktop.
Madhanagopal
INDIA
Discussion Q&A:
Rob
Madhanagopal
INDIA
Discussion Q&A:
solid..
Regards
Rob Pickers
pickcadd@sai.co.za
