Have you tried using DesignCenter for this? (Don't know if it'll work any
better, but maybe worth a shot.)
Also, just a suggestion, but perhaps re-think your 'let's use the std detail
from the network library idea' - that sounds like the path to project
perdition to me.
Instead, maybe have a standard folder layout for your projects, one of them
being "Details".
Then, COPY the std details you need for the project du'jour FROM the Network
Library TO that Details folder.
Then, just use relative paths for your xrefs, pointing to,
..\Details\DTL_X.dwg, say.
Much more standardized system, IMO, AND much less prone to having some
nit-wit hose 50 projects in one fell swoop by modifiying a "Standard" detail
that should've been left alone.
Best regards,
David Kozina
"magic8ball_2k" wrote in message
news:31200606.1099328565062.JavaMail.jive@jiveforum1.autodesk.com...
> Hi all,
> I am trying to create standard sheet layouts to be inserted as blocks.
> Each sheet layout contains Xrefs to standard details on the network.
> The problem is, when I insert the sheet layout into a new file, the Xrefs
> do not show up. I receive messages stating that the Xrefs are converted to
> standard blocks, yet these blocks are "empty".
> Is there something I'm missing? Please Help!
