AutoCAD 2000/2000i/2002 Archive
New Member
Eric Meyer
Message 1 of 4 (1,556 Views)
Inches to decimal feet
1556 Views, 3 Replies
09-11-2004 06:31 AM
How do I convert feet and inches to decimal feet? For instance I'm trying to get 3-3/8" to look like 0.28'. Or 18-1/2" to look like 1.54'. I'm running a program called QuickSurf which works within Autocad to develop topographic maps and other surface views by using Autocad's points. QuickSurf uses Autocad's polylines to draw the topo lines and uses Autocad's layers, colors, text styles, and units of measurement. I entered my elevation data as 3D points and my unit of measurement was inches. But now I want QuickSurf to draw in the elevation data by each point in decimal feet. Since QuickSurf uses whatever unit of measurement Autocad is currently set to use I just need to know how to get Autocad to use decimal feet instead of inches. When I format my units to decimals Autocad thinks I want feet and decimal inches. This of course does me no good.
*Dean Saadallah
Message 2 of 4 (1,554 Views)
Re: Inches to decimal feet
09-13-2004 06:23 AM in reply to: Eric Meyer
SCALE your drawing up x12, then set units to DECIMAL. Remember to add ' to all your dimensions using the DIMPOST variable. -- Dean Saadallah Add-on products for LT http://www.pendean.com/lt --
*Stephen R
Message 3 of 4 (1,554 Views)
09-13-2004 07:00 AM in reply to: Eric Meyer
In your dimension style, use a "measurement scale factor" of 1/12 (or .08333). This will convert your inch dimension value to feet. Then just add a ' as a suffix. Stephen R. "Eric Meyer" wrote in message news:24844948.1094909513516.JavaMail.jive@jiveforum1.autodesk.com... > How do I convert feet and inches to decimal feet? For instance I'm trying to get 3-3/8" to look like 0.28'. Or 18-1/2" to look like 1.54'. I'm running a program called QuickSurf which works within Autocad to develop topographic maps and other surface views by using Autocad's points. QuickSurf uses Autocad's polylines to draw the topo lines and uses Autocad's layers, colors, text styles, and units of measurement. I entered my elevation data as 3D points and my unit of measurement was inches. But now I want QuickSurf to draw in the elevation data by each point in decimal feet. Since QuickSurf uses whatever unit of measurement Autocad is currently set to use I just need to know how to get Autocad to use decimal feet instead of inches. When I format my units to decimals Autocad thinks I want feet and decimal inches. This of course does me no good.
*Stephen R
Message 4 of 4 (1,553 Views)
09-13-2004 07:03 AM in reply to: Eric Meyer
Sorry about that, I read this as a dimension question, when it is actually a software usage question. Stephen R. "Stephen R" wrote in message news:4145a8d6$1_3@newsprd01... > In your dimension style, use a "measurement scale factor" of 1/12 (or > .08333). This will convert your inch dimension value to feet. Then just > add a ' as a suffix. > > Stephen R. > > > "Eric Meyer" wrote in message > news:24844948.1094909513516.JavaMail.jive@jiveforum1.autodesk.com... > > How do I convert feet and inches to decimal feet? For instance I'm trying > to get 3-3/8" to look like 0.28'. Or 18-1/2" to look like 1.54'. I'm > running a program called QuickSurf which works within Autocad to develop > topographic maps and other surface views by using Autocad's points. > QuickSurf uses Autocad's polylines to draw the topo lines and uses Autocad's > layers, colors, text styles, and units of measurement. I entered my > elevation data as 3D points and my unit of measurement was inches. But now > I want QuickSurf to draw in the elevation data by each point in decimal > feet. Since QuickSurf uses whatever unit of measurement Autocad is > currently set to use I just need to know how to get Autocad to use decimal > feet instead of inches. When I format my units to decimals Autocad thinks I > want feet and decimal inches. This of course does me no good. > >
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
