Sorry about that, I read this as a dimension question, when it is actually a
software usage question.
Stephen R.
"Stephen R" wrote in message
news:4145a8d6$1_3@newsprd01...
> In your dimension style, use a "measurement scale factor" of 1/12 (or
> .08333). This will convert your inch dimension value to feet. Then just
> add a ' as a suffix.
> Stephen R.
> "Eric Meyer" wrote in message
> news:24844948.1094909513516.JavaMail.jive@jiveforum1.autodesk.com...
> > How do I convert feet and inches to decimal feet? For instance I'm
trying
> to get 3-3/8" to look like 0.28'. Or 18-1/2" to look like 1.54'. I'm
> running a program called QuickSurf which works within Autocad to develop
> topographic maps and other surface views by using Autocad's points.
> QuickSurf uses Autocad's polylines to draw the topo lines and uses
Autocad's
> layers, colors, text styles, and units of measurement. I entered my
> elevation data as 3D points and my unit of measurement was inches. But
now
> I want QuickSurf to draw in the elevation data by each point in decimal
> feet. Since QuickSurf uses whatever unit of measurement Autocad is
> currently set to use I just need to know how to get Autocad to use decimal
> feet instead of inches. When I format my units to decimals Autocad thinks
I
> want feet and decimal inches. This of course does me no good.
