Here's a wild one.
We've just gotten our whole office onto AutoCAD 2002, and now people are
reporting problems with Direct Distance Entry.
What happens is: you run a command - say Copy.
Pick an object
Hit the Space bar (that's important) to finish the Selection set.
Pick a point with the left Mouse button.
Move your mouse in the direction you want to copy.
Type in a distance (say 8') and hit the Space bar. to finish the Direct
Distance.
Do a distance between the two objects, and they are 7'-11 7/8" apart.
This seems to ONLY happen when you use the space
bar. Not the Right mouse or the Enter key. It also appears to be off
by the distance of your Units tolerance times the number of space bars
typed. We use Units set to Arch & 1/64 tolerance
At the command line:
UNITS 4 64 1 2 0 N
This is causing MAJOR problems for us - Anyone
have any ideas?
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"kmc" <I'm
href="mailto:keith.challinor@cadassist.co.uk">keith.challinor@cadassist.co.uk>
wrote in message
href="news:f16ed78.15@WebX.maYIadrTaRb">news:f16ed78.15@WebX.maYIadrTaRb...
with Chis on this one I to have legacy DWGs altering the priority for
coordinate data entry
Should normally be set to KEYBOARD EXCEPT SCRIPTS
Keith
Please, DO NOT send technical requests to me via private e-mail
Tracy W. Lincoln
Assistant Moderator - Autodesk Discussion Forums
Discussion Group Links:
Index: http://discussion.autodesk.com
Rules: http://discussion.autodesk.com/webx?groundrules
Direct Distance Entry with ArchT in AutoCAD 2000-2002
There is a problem that has been around for awhile using Direct Distance
Entry with ArchT in AutoCAD 2000-2002. Direct Distance Entry is the method of
COPYing or MOVEing entities by pointing in the direction you want and typing in
a distance on the keyboard. Although many are aware of the problem not everyone
knows how to get around it. Thanks to the help of a user and some research on
our part we have been able to identify the exact conditions under which the
problem develops and how to avoid it.
In order to avoid the problem you first need to know how it is caused. To see
the problem perform the following steps:
In the Utility>Preferences>Session menu on the Commands tab check the
box 'Enable Enhanced Commands'.
Turn ORTHO ON
Select the COPY command
Select the objects you wish to copy
To finish selecting objects press the SPACEBAR (not ENTER or a right mouse
click)
Drag the crosshairs to the right and up so that the selected entities are
dragged at angle 0
Instead of selecting a point type in a distance on the keyboard followed by
the SPACEBAR (example: 8')
Using the DISTANCE command measure the distance between the two objects.
Results: The distance is off by varying amounts
To avoid the problem keep the following tips in mind:
1. With ORTHO OFF it is impossible to cause the problem.
2. Using the ENTER key instead of the SPACEBAR will not cause the
problem.
3. The problem only occurs with the ArchT enhanced versions of the AutoCAD
commands.
4. It is possible to use the SPACEBAR only IF Polar Tracking is turned ON and
the angle of the line displays next to the crosshairs.
5. You can explicitly specify the angle and distance as in 8'<0. With the
IntelliCAD version of ArchT you must use this method.
We expect to fix this problem in the next version of ArchT.
"Tracy W. Lincoln" <And
href="mailto:discussion.support@autodesk.com">discussion.support@autodesk.com>
wrote in message
href="news:3EF0B3DB.CDA4E951@autodesk.com">news:3EF0B3DB.CDA4E951@autodesk.com...
that 3rd party app would be.................?
Please,
Tracy W. Lincoln
Index:
href="http://discussion.autodesk.com">http://discussion.autodesk.com
Rules:
href="http://discussion.autodesk.com/webx?groundrules">http://discussion.autodesk.com/webx?ground...
>> The problem with direct distance entry turns out to be an AutoCAD
bug. I am
>> waiting for a response from them to see if there is an
alternative.
So, it looks like it comes full circle, after
all.
"DaveP" <dplumb_at_bwbr.com> wrote in message
href="news:690F3414ED5EDF08FA76BBDAC0691CD3@in.WebX.maYIadrTaRb">news:690F3414ED5EDF08FA76BBDAC06......
OK, I'm ready to make it public.
The application is ArchT.
Here's their explanation and
work-around.
I'm planning on turning oiff the enhanced MOVE
and COPY commands, although that may have some other side
effects.
in a distance on the keyboard. Although many are aware of the problem not
everyone knows how to get around it. Thanks to the help of a user and some
research on our part we have been able to identify the exact conditions under
which the problem develops and how to avoid it.
see the problem perform the following steps:
Turn ORTHO ON
click)
dragged at angle 0
objects.
problem.
commands.
and the angle of the line displays next to the crosshairs.
the IntelliCAD version of ArchT you must use this method.
wrote in message
Tracy W. Lincoln
Index:
Rules:
href="http://discussion.autodesk.com/webx?groundrules">http://discussion.autodesk.com/webx?grou...
wrote in message
Please,
Tracy W. Lincoln
Index:
Rules:
href="news:AA562729AFD4E62EA1482175853BD0CB@in.WebX.maYIadrTaRb">news:AA562729AFD4E62EA1482175853......
I'm trying to protect the guilty
here.
I'm talking to the developer to make sure it
really is the problem.
Once I've confirmed it or he's fixed it, I'll
post the name.
wrote in message
Tracy W. Lincoln
Index:
Rules:
